1 - 11 of 11 Posts
After plowing snow for 2 hours my winch would become really slow then have no power right after then I couldn’t use my electric start. I had a spare battery so I installed it and it did the same thing so I parked it in the garage and it started next morning no problem I didn’t use a battery charger or anything and the winch worked fine and sounded healthy. Wondering what my problem could be if it’s the stator or a ground somewhere
You are using more amps running the winch than the ATV can produce.
Start out by putting a trickle charger on the battery when its parked. Start out with a full charge. Have the battery tested and see if its week.
About the most amps the ATV can produce is 25 amps and that's at over 5,000 rpm. Your winch is drawing 85-125 amps every time you use it. PLUS YOU NEED AMPS JUST TO RUN THE ATV AND ANY OTHER ACCESSORIES THAT ARE ON.
Your fighting a loosing battle.
The battery I’ve put in is brand new and the quad starts fine after sitting for a night and winch sounds healthy. I tested it and it reads 11.9 volts
A full charged battery is 12.8 volts. At 11.9 its 75% discharged. Did you activate and slowly charge the new battery before install? GET A BATTERY TENDER
You have not mentioned what make, model, year ATV you are using; other accessories on while plowing. As said, you are likely abusing/misusing the battery. 11.9 V is not good. Your battery is recovering, to some degree, after resting. Keeping a battery tender hooked up while sitting will help. as will keeping your plowing sessions shorter.
It’s a 2000 sportsman 500 with just the winch and stock headlight I unplugged my led lights after the first time it killed it. I left it on charge overnight and I’m going to be doing some tests. I found one wire that’s short circuiting but I don’t know if that would be enough to kill a battery
One of the things I found with a Battery Tender kept on 24/7, it seems to shorten the life of my batteries over time, especially water filled type. The Tender's boil the water out in a short time, especially in the summer. I have all of my toys in the "Toy Barn" on one timer. I only allow the battery charging to happen during the summer from midnight until 6 am. This is the coolest time of the day and has extended the life of all my batteries. Cab-Over camper 1- 12v deep cycle, Toy Hauler 2- 12v deep-cycles, both Polaris quads, 700 & 800, my new Polaris General and a commercial 72" mower. Mowing is almost as much fun as a quad trip, well it provides a lot of relaxation mowing 6+ acres, with a beer.
You need to get a 3 or 4 stage charger/tender. That's all. I keep mine on continuous when I'm not riding - 3 years now, no ill effects. Might be something with the batteries as well. Same with the 4 deep cell house batteries in my Class A MH (6 volt wet cells). No boil over - I check my batteries monthly, in two years I've had to add water one (less than 4 oz. total). If you are overcharging your batteries you need a different charger/maintainer. Of course you can continue doing as you are, it seems to be working for you.
1 - 11 of 11 Posts
