Hey ehats going on guys. I recently bought a Predator 500 & it didnt start so we took it apart & found a mess of stripped bolts & broken bearings. 2 days ago I replaced my stator, flywheel, starter clutch & bearing, starter gear, needle bearing, & idling gears. Then it starts up & rides good but once its warmed up & driven for 5 minutes it makes a wierd sort of grinding/ clunking noise ONLY WHEN THROTTLE IS APPLIED, even does it in neutral when reving engine. & the sound is coming from the stator/flywheel area. Any ideas ?!?! Thanks in advance !!
