Does anyone know of a way to tell the difference between models and years by visual cues??? Or a website?
I have an early model two stroke with an unreadable VIN stamp and its driving me crazy!!! Ive given the local shop 3 different tries and all are BAD! :bam:
Thanks peeps!
Try Powersports network. They have a great make, model and year specs for almost all atv manufacturers. Not sure how far back on the years they go on the specs. Check out the reviews on the machines.
there is also an engine stamp that will at least narrow down the year and then if you can show us pics then we should be able to come up with the model . Kinda weird that they would be worn off or was it on purpose ( i sure hope not ) , if you got a title with it , it would also be on the title .
I have also done the paper and pencil rub trick and the #'s will come forth , sometimes they are just so camouflaged you can't read them .
Give us a try , we will figure it out .
I think what you have is a 06 trailblazer 250 with some creative welding work on the rear- I dont remember that stuff on any polaris trail blazer (could be wrong though on that)
maybe 06 because of the yellow springs which were unique to the 50th anniversary edition - or the springs were replaced or painted - I see spots of red on the bottom of them
if it's an 06 the gas tank must have been replaced as the tank on the 06 was black not white
the vin is stamped on bottom of driverside frame up front, might be able to see it still - go check
its definitely a trail blazer 250 though - grips on it say its a late 90's model though but could have been replaced.
looks like the dash / ignition was painted so that probably means the springs were painted so they were red, makes it a late 90's model
the brake master on handlebars is aftermarket - they never made a clear white one
whatever it was, it looks like someone used it as crab trap bait
needs a frame off resto
tires are backards as well - tread pointing in wrong direction
Yeah, I call it the Franken-ride! My Father-in-law picked it up without letting me take a first look at it and of course, I never turn down a project, so here I am!
The rear rack is anything but factory!! It's conduit that was twisted and turned to become a useable rack (quite the ingenuity). It has 3 layers of paint, the final being a shade-tree-windy-dusty-day camouflage scheme that I'm trying to make disappear!
I've tried to interpret the frame VIN 3 times now and all three have failed. It looks like it was "printed" with a dot-matrix into the metal!! HAHA
Maybe a pic and you all can try your luck in decyphering it?!? I'll try the pencil scribble first (GREAT idea!!)
WOW!
I woulda' bet $$$ that the 4th digit was a "3"!!!
How about the 11th & 12th digit?
Guess I need the manual with the VIN breakdown/explanation!!!
Much thanks for your interpretation, RazBarlow, as well as everyone else!
Not worried at all that its stolen...picked it up from the electric co-op rep out here where we live. He's a good 'ol boy (older man) and he used it to tool around on his farm.
Raz, I'm right next to Fort Hood, in Gatesville. A few more hours south of you.
Those should be the only numbers I need. We needed it to give the Polaris shop in Waco in order to get a new rear shock...speaking of which, this one has a Bilstein on it. Was that a Polaris OEM item?
Look on the cross bar behind air box, some had vin # stamped there too.
Related Threads
876.5K posts
113.4K members
Since 2008
