Well figured since quad's going be in hospital for a while
Might as well. Build audio tube. What u think 750 watt
Marine amp overkill? 2- 51/2" marine speakers.
Welcome to the board!:med: And over Kill.
What size PVC are you planning on using? Ive been researching an audio tube build as well and it seems 6" PVC with 6.5" speakers is pretty standard and the most affordable. With 6" PVC, I think there are only a few amps that will fit inside. The boss cx150 and the ssl 2.200 are a couple I've found.
Unless you are building a special box for the amp, I have never seen a 750w that will fit in a 6" PVC. Most use small motorcycle amps between 100-300w, which are enough for a 5 1/2" speaker in PVC.
