1 - 14 of 14 Posts
Forgive me as this might be a stupid question, but as far as I can tell Aluminum ATV wheels use regular automotive Valve Stems right?
yes they do!!
Anytime!!
Reactions: MrEd
I use the shortest stems available (1 inch long) when installing the common rubber pull in valves, but prefer the bolt in variety - still fit the standard .453" (10 mm) hole
NO!!! You cannot use standard automotive valve stems!!! They take a proprietary valve stem!! I have them available, $75 each! Your quad will lose it's tires if you don't use the ones I have!!!! PM me so I can set you up with a set!
Ok, maybe not......but I'll still sell you some for $75 each if ya want!!! 🤣 🤣 🤣 🤣 🤣 🤣 🤣
Discussion Starter #8
Thanks Latebird, great info!!
Discussion Starter #12
Sorry.....needed a laugh.....that still cracks me up
1 - 14 of 14 Posts
