hi, ive just bought a polaris diesel quad (one in picture) not sure of age/model, it starts runs and drives well. only problem is the AWD dosnt seem to work, the awd light works when switched on. the previous owner has fitted a toggle switch for the starter as he said the switch cluster on the left hand handlebar got water damage, could this be the reason for awd not working, also the speedo dosnt work i read somewhere if it dosnt the awd wont on newer models?. any help/diagrams appreciated
:veryhappy:
Greetings. I believe Polaris only made the diesels for two years, 98' & 99'. You will need to fix your speedo to get your awd to work or you can use a jumper wire to juice up the AWD .
There are manuals you can download for free on this forum. :veryhappy:
Welcome to the board.:med:
thanks for replying, cant seem to find the manual for this, do you know which wires to hard wire to get it working, thanks
