So i've been tearing into this 98 xplorer 300 all week. I took the shifter out today to adjust the rods and noticed the shifter box wasn't closed. It was open almost 1/4". So i took it out, drained it, flushed it and filled it with no fluid. It used to sometimes show neutral while in gear and now that i adjusted the rods it it only shows neutral in neutral. My issue is my awd doesn't work anymore. It lights up in neutral but when i go into Forward or reverse the light goes out. Trying to figure out how that could have happened as the only electircal in the shifter is the neutral switch. Any ideas? How can i go about finding an electrical diagram for my quad?
So I just tore into the shifter again. The switch seems finicky and I can get reverse to light up some times but no matter what still no awd in gear. Even tried by passing it connecting red/w to grey/w and same thing. Only awd in neutral.
You may just have a bad switch or ground. The AWD works by grounding or not grounding. The switch is NOT just for neutral. It does R, N and L and the machine MUST be in gear for AWD to function. There is a hack for a AWD bypass ground on the forum somewhere but I can't remember where to point you to...sorry.
I already did the hack and it didn't help. I still only get AWD in neutral and if i put it into gear and pull back slightly i can get it to light up. So some how even with the switch bypassed it still only shows in neutral lol.
So did you disconnect the switch altogether and try jumping the two wires? You won't have a gear light, but if you bridge the plug that the switch would plug into, it should light up the 4WD light.
Give it a shot, 'cuz I had the exact same symptoms on my diesel sportsman, with the same style 4WD, and when I just bypassed the switch completely by just bridging the machine side of things on the harness, it got rid of every problem I had with the 4WD, including the nice fact, you no longer have to hold the override button down going in reverse if you want 4WD. Good luck!!
ok, just disconnected the switch all together and no AWD or neutral light. Tried disconnecting just the red/w and grey/w wires and jumping the board and still nothing. It's so weird i'm gettting opposite of what i need and why it would only show in Neutral.
That is bizarre. It almost makes me wonder if something up stream of the harness is bad, or you must have a bad ground somewhere in the system. IDK, that's weird. :/ Have you taken the 4WD switch apart and physically cleaned the contact plates? That could be your issue as well. just be careful pulling out the springs and pins and stuff.
So got it all back together. Now some times itll engage 4wd shifting into H with the button depresed and some times it wont be either way 4wd doesnt light up other than in neutral. Hitting the 4wd switch while in gear still does nothing.
Related Threads
876.5K posts
113.4K members
Since 2008
