1 - 2 of 2 Posts
Awd indicator on 2011 sportsman 850xp is not displaying when switched in 4x4 and it is not going into 4 wheel drive. What do I need to check first? Is it the switch that is bad?
Hello, Did you end up figuring out how to fix the AWD switch, I am having the same issue, when I switch it into 4x4 the 4x4 on the display shows up then disappears and it doesn't connect. However the ADC when switched the 4x4 works, but switching back into 4x4 it stops working. I am wondering if you fixed your system.
1 - 2 of 2 Posts
