This ^^^. Open center hub cap , drain fluid and wipe clean, tighten cap back in place and replace the fluid with either Polaris Demand Drive Fluid or if you don't have any handy and want to try it sooner ATF Type F fluid 3.2oz in each hub. Rotate hub until the plug screw is at three o'clock, fill fluid until it starts to spill out, plug screw and rotate tire a few times, go back to three o'clock open plug screw and slightly turn hub toward four o'clock, let the little excess spill out until it stops, then rotate the hub back to three o'clock or less and tighten the plug.
Rinse and repeat for the other side.
