1 - 8 of 8 Posts
I have a sportsman 570 and by now I know my clutch is bad by the way its worn out but it all started with my shifter being hard to shift and having to turn off my machine to get it in to a different gear then every time I would go ride It would destroy my belt within a couple hours I'm in the process of getting a new primary clutch hoping that is going to be the solution because from the videos and some stuff I've been reading it might be from a bad bearing I. The primary clutch, but I'm wondering if any body else has had this problem and if just a new primary clutch would fix it
Welcome to the forum
Clutches need to be serviced and cleaned on a regular basis. You're not saying what year it is and if the clutches ever had any maintenance done.
You also need to service your secondary clutch at the time you put a new primary on.
Reactions: Cris1002 and MrEd
So basically the bad one way bearing is over heating your belt and that's what's destroying it. How many hours/miles on it and what type of riding do you do? As well as do you have over sized tires??
Reactions: MrEd
2017 Sportsman 850SP
Looking at the pictures, you definitely need a new primary as your sheaves are worn to $hit. Could have been avoided with proper maintenance, but thems are the breaks. Take off your secondary and make sure it gets a good servicing or is replaced if it's in as bad of shape as your primary. Then when you get everything installed, check your belt alignment and make sure it is correct. After all of that, proper belt break in is in order and you should be trouble free until the next regularly scheduled maintenance. That is of course, assuming you have a stock atv and you ride in "normal" conditions.
Good luck!
Reactions: MrEd
1 - 8 of 8 Posts
