Hey everyone I just thought I would throw my two cents in here. I've seen a lot of threads about people trying to decide on a winch. I decided to go with the badlands 3000lbs winch from harbor freight. It was $116 with a coupon and I gotta say I'm impressed. Install was pretty simple and straightforward. They give you everything you need to install it minus the mount of course. The only issue was putting the contractor on. I had to get a little strip of metal and attach the contractor box to it then attach that to the radiator support. It's a tight fit so you can get it without touching the radiator but its easily doable. They Los give you a handlebar rocker as well as a wired remote. I just zip tied that plug to the a-arm until I find a better spot for it. The winch is very smooth and quiet and seems like its made pretty darn well for the price. I used a KFI mount and it just slid in. Anyways I thought I would just throw that out there for anyone wanting to not spend a fortune on the winch.
