I have an 04' sportsman 700 twin. I just bought a badlands 3000lb winch and I'm confused on how to mount it. I want to mount it between the headlights in the "winch pocket". Where I'm stumped at is how to get the supplied mounting plate in. Do I need to remove the whole front plastic etc? Any help would be greatly appreciated
I have the same winch on my 700. I welded the supplied winch plate to a piece of 1.5" stainless steel thick wall square tubing and drilled holes, 1 in each end of the tubing. Using 3/8 stainless bolts, it mounted to the frame with no problem. Pulled myself out of the mud many times and still holding strong.
