I have noticed some slight up and down play on my ball joints, with it jacked off the ground. It’s a 2013 500. I assume there should be zero play.
What is the recommended replaced. OEM or is there something stronger. Is it a pain to replace? I think I would try and purchase the removal tool. Those tiny screws that hold the cover look like they will be fun to remove.
Tool or some cut pieces of pipe and plate would work. I've never had trouble with the screws. I use OEM ball joints. I've come to accept some play. If I didn't I would be replacing parts ALL the time. Little heat and freezing the ball-joint goes a long way on the installation.
So true. Maybe I shouldn’t be so picky. Thanks for the pipe idea. I guess the pipe would be bigger than the joint. And you would pull it out through the plate.
Definitely freeze the new BJ and heat the bottom of your strut before installing the new BJ. A propane torch works fine, just give it a couple minutes. The new one slides right in with minimal effort.
I don't bother to pull the strut off the machine anymore. Just hookup my puller, heat the bottom of the strut for 2 mins and yank the old out. Clean up the bore, re-heat, and slide new in.
Awesome. I’m going to make that puller
Nice!!! Thanks Mike for posting up that link!! That's the one I was thinking of.
