2008 trailblazer. Nephew bent a control arm on a tree, has a loose ball joint so I'm replacing both.
This has the greaseless type. I'm finding OEM, all balls, tusk, epi and a bunch of others. Should I just stick with OEM or are the all balls/tusk etc a safe bet?
I have generally used the aftermarket ones. Mostly because the OEM parts have not been available or are real expensive. Never had an issue with any of the aftermarket ones I have used.
I bought the All Balls and installed them today. The originals were trashed. No problems putting them in... Getting the old ones out wasn't a good time.
