Hello to all!! I have a questions regarding my battery. I have a 2013 Sportsman 850 XP EPS LE. I have a plow, 2500 Winch, and fog lights. I also have brush guards front and back. Anyways, I plow three short driveways. No lights on, in Low. After so long. The battery dies. I called the dealership. They say that because your in Low and the Winch uses so much juice. After letting it sit for some time. It starts right up and everything is fine. The battery doesn't get enough time to charge. Has anyone else had this issue? Do you think my battery isn't good. I use a battery tender after each ride too. Quad is stored in a garage with no heat. Thanks all!!!
