i just got a 2007 sportsman 450. it was not taken care of at all.I got it to run but now the battery and wrench light are flashing. and i have no clue where to start:dunno:
The wrench could be the internal clock used for maintenance ran out and needs to be reset, I would check the voltage of the battery. I believe you can do that thru diagnostics. Its all in the manual.
sounds like it may need a new battery. id say take the battery out and have it tested. or charge it. then leave it to see if it holds a charge. if its not the battery its the charging sytem
