1 - 20 of 31 Posts
I have a 2007 Polaris Sportsman 500 EFI. The only modification to the ATV is an oversized piston in the engine. I notice occasionally at high RPM, say 50+ mph, the battery light will start to flash and the ATV will start to lose power. Once you slow down to below 50+ mph, the flashing will stop and the ATV rides normal. The battery is new. Is there a rev limiter in this ATV and how does it work? Please advise on what I can check to resolve this issue.
Voltage regulator problem, sounds like it is overcharging.
Check the charging system.
Is there a way to check the charging system specifically the voltage regulator? Where is the voltage regulator located on a 2007 Sportsman 500? Once again, I changed the battery hoping it would resolve the issue but it did not.. So we can eliminate the battery.
Discussion Starter · #10 ·
2007 500x2 le
Check your battery voltage not running should be 12 to13 volts then start it up recheck batt voltage while reving the engine shouldn't read any more then 14 to 14.8 volts or so if its considerably higher u need a regulator
There is a procedure for testing the stator in the service manual.
What voltage did you get on the battery at RPM? It is the regulators job to take the 60vac from the stator, rectify it to DC, and regulate it to 14.5sh VDC.
My PDM had water intrusion. It has 4 screws on the back of it that hold the cover on. Had lots of corrosion in mine. Might be worth checking.
Sean
Discussion Starter · #17 ·
Sean
I ran the test this afternoon. The DC volts reading on the battery without the engine running is 12.80 volts. With the engine running and with RPM, the battery reading is around 14.60 volts. It will not exceed 15 volts even with high RPM. So based on that test, it looks like the voltage regulator is working. So, what's next to check. Once again, the only modification to the ATV is an oversized piston.
Have you had the battery load tested?
Sean
The ignition coil could be weak. At higher RPM it has to create a field and collapse it much faster than at lower rpm. What you may be experience is the coil breaking down.
Check your primary and secondary resistance of the coil. Also, while you're at it, check your plug wire. If there is any cracks on it then consider replacing it.
1 - 20 of 31 Posts
