Battery not charging.
1 reading
42K views 9 replies 5 participants last post by  RunMoFassa
My battery is not charging, i've tried some of the troubleshooting tips including checking the stator,loose connections and bad rectifier. The stator is fine since it will run without battery connected, no loose connections, and three of the four wires on the rectifier had fire (the fourth wire is a ground). Any ideas of what it might be. Thanks for any help.
#5 · (Edited)
It'a a 2003 sportsman 500 h.o. I'v checked the battery while running with multimeter and the voltage doesn't change. It has a brand new battery, i rode the other day and it cranked fine all day but when i got home i shut it off for about an hour and got back on it and it wouldn't turn over, charged battery put it back in and it cranked fine.
#6 ·
Been reading some related threads and saw where one guy had his rpm gauge quit working about the same time his battery stopped charging and he said it was his regulator, my rpm gauge quit working the same day it quit charging so i think i found the problem. This same guy said the rpm gauge power source ran through the regulator so it only makes sense for that to be the problem, hope it is anyway. Still open for suggestions tho, thanks.
