I have a 450 sportsman 2018 and I encountered a power outage while my unit was on a maintainer. The ground fault on the electric outlet tripped and the battery drained to zero. I was surprised that the maintainer would allow the discharge. I recharged the battery however I believe it may have been damaged. Bottom line...what battery would anyone recommend as a replacement? Unit is garage kept with very light duty.
I replaced my factory Yuasa with the upgraded one, larger battery with more amps and capacity... no issues with factory but wanted the extra insurance of the bigger battery....
Deka is good as well, they make a lot of the other batteries that are out there branded under other names...Odyssey is also very good
Reactions: MrEd
Odyssey batteries is all i us when the OEM have completed their service life.
