Hi, I am looking for some advise on batteries. I have a 2015 sportsman 570 w/ESP.
Ive had the machine for a few months now and love it. I installed a marine grade stereo with handlebar controller, as well as some additional lights. Two
PIAA 55w headlamps on the front bumper and one Generic 50w headlamp that i tucked up under the trunk for a reverse light. (skipped the in depth relay route and just installed a micro push button switch on the inside of the shifter knob) Anyway without a backup pull start im afraid to run much of anything for more than a minute without the engine running cause my display cluster constantly reads low battery voltage.
My question is this. I decided to upgrade to a deeper cell glass mat battery and would like to get a bigger one then the machine is designed for such as a 16 as opposed to the 14 that came with it. If I do this could I cause any harm to my machine and will my stator be able to efficiently and fully recharge/tend the bigger battery ??
If anyone knows more able these charging systems or could help that would be awesome ! .... ( I do know i may need to modify the mounting area to hold the physically bigger battery but thats no prob).... THANKS
I'd swap out those lights with LED's. The stator can only produce so much power, not sure the bigger battery will help much.
+1 on swapping out those lights. A bigger battery would only give you a few more min of runtime. I can't be 100% but I believe a bigger battery would take longer to charge back up once you run it down due to the stator.
If it helps I am running Polaris LED Headlights, LED taillights, 2 48w LED lights on the brush guard, 2 18w LED lights on my plow, an 881 LED in my headlight pod, heated grips & thumb warmer on high and constantly running my winch on the OEM stator and equivalent OEM spec battery without any issues at all. Such can be the efficiency of LEDs.
