Help. I was out riding today went to go put it in reverse and the shift selector just moving back-and-forth. It was stuck in low so I made it home. When I took some panels off and went to inspect. the splines inside the bell crank lever are all stripped. It’s obviously easy enough to replace however it looks to me like some of the splines on the shaft might be damaged. Would someone please guide me as to how difficult and what is entailed in replacing that shaft If I need to. Thank you
