· Registered
How do you change the belt on a 2014 Sportsman 400? Do you pull up in it and roll the secondary until it works off, or do you use the tool to open up the secondary? I'm asking because I'm about to install a clutch kit I ordered from RVS and knows I will need to remove the belt and put it back on. Thanks in advance
· Registered
No I don't I watched the video by RVS and his primary was on
· Registered
Ok, you can roll the belt over top of the secondary, just watch your fingers.
Also, your secondary is not like the one on the XP/RZR, no spreader tool. Below is a pic of cltuches from my 2012 400HO.
Good luck, and when you can, please update us on the performance of the clutch kit.
· Registered
Thanks for the response, and I absolutely will.
