I have a 2012 sportsmen 500 with 600 miles belt sarted to slip replaced belt plastic buttons in clutch and put in an epi clutch kit after 3 rides belt is slipping again any ideas
Is the belt you put on OEM, or after market? Have you checked your engine mounts to make sure none are broken?
Sean
Are you riding it in the water at all? Could the belt be getting wet? How are you riding it? More details please.
Definately need more info. Is the belt OEM? Did you put everything back together properly when doing the clutch kit? Did you put some break-in miles on the new belt before giving it hell?
I'll add to the list of pertinent questions....stock tires?
put on oem belt, stock tires, and x on the the drive clutch so it would line up .haven't rode in any water since I put in new belt. I will check the engine mounts tonight. I have done some break in on the new belt.
Did you preload the secondary 1/4 turn counter clockwise before cliping it down?
well it looks like I didn't have the belt deflection set right after I put the clutch kit in thanks for the help with my problem.
