Just need a lil input. long story short. I buried my Silverado in mud (stuck). I was riding my 2013 Polaris 500 around the truck to access the situation. I had it in 4x4 and in high kinda in a tight pinch(right) turn and gave it pretty good throttle and for a about 1 second blue smoke rose from i assume the belt housing. I guess I should have had in low range. But just wondering if anybody has had this happen? Once I shifted into low never had anymore problems. P.S. Paid $100 for a wrecker to pull my tractor and truck out which I thought was reasonable.....pay to play.....lol
You should always use low gear when in mud. Your belt life depends on a lot of different things and situations. Depends on how the new belt was broken in and how it has been driven. Are aftermarket tires involved, thick mud, towing, etc?
Tried to break it in easy, pasture riding, dirt roads basically on the farm. I do have after market ITP Mudlites XL on the rear and Kenda Executioner on the front pretty aggressive. Plus I had the wheels turn hard right in a bind so I think it was my fault in high gear. Its all good now just wanted to get some feed back...thanks
You would benefit from proper clutching if you have not done so already. A good clutch kit from QSC would help to lengthen your belt life, especially with aftermarket tires.
Probably look into it as Spring time rolls aroiund
