1 - 20 of 23 Posts
What is best front axle for stock height and tire size? I broke a front axle....
I have gone thru a lot of eBay Chinese axles to popular brands in mud races and found my home at super Atv. There axle is by far the strongest with best no nonsense warranty for the money. They run about $200 each.
and are these axles as strong as gorilla axle or other axles that mud guys use? I don't really care about the price, I just don't want to break it again.
Gorilla or highlifter pro series would be the way to go.
if your not planing on lifting or putting big tires american CV there a little better than stock but not as good as gorilla but half the cost
what about oem axle from earlier model year xp? hear they are much stronger
Are they still available?
2009 is the year to get them from. The outter bell of cv is 79mm vs 73 now. There is a set for sale in classifieds listed as 2013 but they are the 2009 model from looking at cv bell machining.
The highlighter & gorilla models I tried cv joints ran hot which I did not care for. Like I said earlier the super Atv axles held up best plus warranty from what I hear is second to none!
The real HD axles like gorillas are made to be cooled by being submerged all the time, so blasting bush roads will overheat and blow the boots.
Just about every aftermarket option will be better then stock, so since your not lifted just go for rhinos.
I've never heard that before. Not that I don't believe you but did you read it somewhere? Or was it word of mouth? Them things must get really hot.
Look at highlifter DHT axles
Sent from my SCH-R970 using Tapatalk 2
Discussion Starter · #13 ·
my dealer only change the outer joint under warranty, not the whole axle... so better axles will be only for the next time it will break
I personally really like the HL DHT axles, I haven't had any problems with them. Rhinos are also good, although I haven't had any experience personally with them. But money is no object axles I would go with Gorilla, Cobra, Turner, or HL Pro Series.
Last atv ride gabbing with a guy who had a lifted 900xp RZR, said it happened to him, also recommended DHTs
Its the same as the sportsman
Rick,
Any thoughts on the Cobra axles? Somebody posted on here a picture of the Cobra next to a broken Gorilla axle and the Cobra was actually slightly larger and doesn't run hot (so the internet says). $250 each and I read they have a lifetime warranty.
I took my chances and ordered a set this afternoon....
1 - 20 of 23 Posts
