1 - 8 of 8 Posts
· Registered
I am having trouble with an 07 Ranger 500 EFI running well. The ranger has been running rough, bogging down when under heavy load, rough idle, you name it....just running bad.
Have replaced MAP Sensor and Harness as well as the idle air control sensor.
To go further I need some specific readings and would love something like the Check Tech Scan Tool but what's available is for 2009+ Models.
What's the best diagnostic / scan tool for these older models? I need to read things like what the check tech does:
  • TPS percent
  • TPS volts
  • RPM
  • Fuel level
  • Calibration info
  • Vehicle miles
  • Engine coolant temperature
  • Intake air temperature
  • Baro pressure
  • Manifold air pressure 1 bar and 3 bar
  • Manifold air pressure voltage
  • Ignition timing
  • Fuel rate
  • Vehicle speed
  • Speed limiter
  • Gear position
  • Gear position voltage
  • Throttle safety switch voltage
  • Throttle safety switch state
  • Power steering torque in
  • Power steering torque out
  • Power steering module temperature
  • Power steering current draw
  • Brake state
  • AWD state
  • High/low beam state
  • AWD request
  • Idle air motor position
  • Fuel pump state
  • Cooling fan state
Thank You! And Looking forward to becoming involved in your forums :D
· Premium Member
  • TPS percent
  • TPS volts
  • RPM
  • Fuel level
  • Calibration info
  • Vehicle miles
  • Baro pressure
  • Ignition timing
  • Fuel rate
  • Vehicle speed
  • Speed limiter
  • Gear position
  • Brake state
  • AWD state
  • AWD request
  • Fuel pump state
  • Cooling fan state
Welcome to the forum
Reactions: C2GCPVA
· Registered
· Registered
Discussion Starter · #7 ·
This looks like an awesome tool, called and spoke to the company. May just have to go through with acquiring this one, If I do ill share my experience! I need to read full live data
1 - 8 of 8 Posts
