1 - 10 of 10 Posts
Well I am in the process of fixing up my Sportsman 500. Which wheel spacers are the best, and do they have the same stock stud sizes?? And is there nay chance spacers can mess my ride up? Thanks
Adding spacers may stop you from access through some areas. Personally I don't care for spacers as You are adding someplace for the nuts to come loose and as they are out of view probably won't get checked, also I feel they add a bit of stress to the bearings as the weight is not carried as designed. I do not care for spacers, but that is just my opinion.
Fred
I have my Flame Suit on ! !
Alright I appreciate it!
Are you adding bigger tires and need clearance?
Matt
Well where I live it's all hillside. So I should gain stability, and it looks pretty sweet. But If they dont have the same stock stud sizes I will do without them.
4/156 is the stud pattern and www.superatv.com has the for best price i have found. I love the added look and function my 1" spacers gave me!!!
Matt
Yea I know the bolt pattern but is the studs the same length and diameter as the stock studs? I wanna make sure I can still run my aftermarket wheels
They were actually about an 1/8" longer over stock.
Matt
Ahh thanks so much man! You just helped me and my ride out so much!
No prob buddy!
Matt
1 - 10 of 10 Posts
