1 - 18 of 18 Posts
I got a 2018 Polaris sportsman 570 SP with power steering and the factory aluminum wheels. Does anyone know what the biggest tire is I can put on those wheels without putting a lift kit?
28" diameter, 9" wide up front and 12" wide in the rear is the limit.
Great. Thanks! Putting the lift kit aside for now. Is that the biggest tires those wheels will take?
Yeah thats the limit. Going bigger will require a lift, offset a-arms, or arched a-arms with an offset. To go wider the front will need a spacer or offset rims.
Yes I under stand that. I was just wondering what the biggest tire is I can put on that wheel. Can I put 30's on them if I do the proper lift kit and spacers?
Yes. Your in clutch country now too!
Don’t know for sure but axles might be or become an issue to.
Damn your good! I think I'll just stick with the 28's. And I'm thinking a lift kit will not give me any more ground clearance correct? Only bigger tires will?
Yes HL has a 2” Lift for your machine, it will add exactly 2” more ground clearance, but will also make it a good bit stiffer to.
I have that lift kit on my 17 SP. actually I have an extra, long story about the local powder coat guy. But make me an offer brand new in box. Not powder coated. But i can coat it if you like. $$.blue, black or orange
1 - 18 of 18 Posts
