New to the site and hating my scrambler right now. Just out of warrenty and whenever I ride its good for about two hours then begins to flash low volt amd count down from 10.9 volts till it kills the entire bike. All my plugs are greased and I cannot figure out the issue. I was hoping the battery had a dead cell but to no advil any advice is welcome. Please help me so I can actually enjoy this damn thing.
Welcome to the board!:med:
Have you used a multimeter on the stator to test the output? Sounds like you aren't charging while you ride.
Seconded the multimeter. Chk voltage at the stator. U can have two good legs and get a good reading at the battery but with out the third charging is insufficient.
also check you voltage rectifier/regulator there known to fail more then stator
