Hi guys
I ran a diagnostic check on my 500x2 efi and the blink code 55 flashed up which in the manual says
MIL Circuit :Open load/short -to-ground
MIL Circuit :shorted load/short-to-battery
Doese any one know what an MIL cicuit is or what MIL stands for.
much appreciated Duane
MIL= "Malfunction Indicator Lamp". ...
Thats all i can come up with....do you have a light out?
what kinda of problem are you having? Starting problem?
g'day muddie
Bike starts fine but after riding for half hour bike stops wait ten minutes and bike runs again. very annoying would the malfunction indicator lamp be causing this?
22 TPS Circuit: Open and Short To Ground
22 TPS Circuit: Short To Battery
23 RAM Error: Defective ECU
25 Transmission Input - Invalid Gear
26 Vehicle Speed Sensor - Implausible
41 Air Temp Sensor: Open or Short Circuit to Sensor Voltage (ECU)
41 Air Temp Sensor: Short Circuit to Ground
42 Engine Temperature Sensor Circuit: Short To Ground
42 Engine Temperature Sensor Circuit: Open or Short to Battery
45 Barometric Pressure Sensor: Circuit Low Input
46 Barometric Pressure Sensor: Circuit High Input
51 Injector 1: Open Load
51 Injector 1: Short Circuit to Ground
51 Injector 1: Short Circuit to Battery
52 Injector 2: Open Load
52 Injector 2: Short Circuit to Ground
52 Injector 2: Short Circuit to Battery
54 Engine Temperature Lamp: Open Load
54 Engine Temperature Lamp: Short Circuit to Ground
54 Engine Temperature Lamp: Short Circuit to Battery
55 Diagnostic Lamp: Open Load
55 Diagnostic Lamp: Short Circuit to Ground
55 Diagnostic Lamp: Short Circuit To Battery
56 Pump Relay Open Load
56 Pump Relay Short Circuit to Ground
56 Pump Relay Short Circuit to Battery
58 Cooling Fan: Open Load
58 Cooling Fan: Short Circuit to Ground
58 Cooling Fan: Short Circuit to Battery
61 End of Diagnostic
Dude check the battery cables....it sounds like they could be dirty or the MLI is heating up and shutting the bike down....MUDDIE
ive seen something very similar to this before. guy installed a winch and didnt tighten the (+) batt cable down so it was loose, and it generated a lot of heat in the electrical system...so his sportsman would shut down to protect itself. same symptoms that you are having
Yo Bro....how'd you make out???MUDDIE49
Howdy
I had a loose cable on the battery but I also took out the thermostat and the bike hasnt stopped since. will try a new thermostat cos it would only get half an hours riding and it would stop with the old one. so hopefuly Im on the right track to an outright fix.
