1 - 2 of 2 Posts
heres my problem. 2005 sportsman 500 HO. i used it to plow all winter and it ran fine. last week i hooked up the trickle charger for 2 days. 3 days after i removed the charger i tried to start it and it was dead. today i tried with a regular charger for 2 hours with the same result.
so i pull start the motor and it starts right up....i give a little gas and the ENTIRE led display starts to blink and then the motor shuts off. now the led is blank. i turn the key off then on and the led lights up normal but it will not crank.
so i pull start again and the same thing happens...it does all this again and again and again.
oh and the winch doesn't work now either
any ideas? its a year old battery
Check the connections well clean them....If the battery had a warranty on it and it is under a year get a new one....if it has no warranty left get a new one ...start there and so how it goes.
1 - 2 of 2 Posts
