i have a 2007 Sportsman 800X2. I had it running and was using the winch. I press the out button and heard a click and the engine stopped. I have no power anywhere. I have checked the fuses under the front panel and they are all good. Where else might there be a fuse to check or any suggestions?
Any help would be awesome.
thanks so much
Did you accidentally hit the kill switch right under the winch switch?
Welcome!
^^^ditto^^^
No, kill switch isn't a factor. Could it be maybe the winch switch went bad and fried something.. Maybe the ECU?
I would check connections at the battery. If all is good there I don't know what else to check. Good luck. Let us know what you figure out.
I believe that if you installed the winch correctly, the installation is isolated from the quad electrical installation.So, nothing might happen with the ECU.
Maybe the battery is in bad condition, did you measure the batt?
Good luck!
Mariano
