I recently replaced my rear master cylinder because try as I might I was not able to get it to bleed out. Once I put a new one in, the problem was solved, however, I now seem to have a similar problem with the front lever master. It hardens up when pumped initially, but drifts down to nothing if I hold it, I can't get it to bleed either. This is on a 2005 Sportsman 800 EFI. I can't believe both of them are bad. Anyone have any suggestions?
