1 - 20 of 26 Posts
Long story short I had my local shop fix my primary clutch today. While working on it, they broke a cooling fin on the back (pic attached). Do y'all think this is going to affect the balance and be a problem? Seeing as how this thing has holes drilled in it for balancing, I think it will, but I'm no expert. I'm also asking polaris. Thanks for the input.
Sent from my SM-G975U using Tapatalk
It will not affect function - if you never saw it you would never know it was missing
Oh yeah, I agree with latebird on that. It'll still work fine.
If its gonna worry you too much you could sell it to recoup some of the cost for a new one.
What's it off of OP?
How many miles/hours on it?
What was done to it at the shop?
That clutch will be way out of balance, I would not run it on any machine.
Haven't balanced many have you?
How affected is the balance when the clutch is rebuilt and new parts installed? Ever built a clutch out of parts from several old ones? Haven't been at this too long have you?
If I was the shop owner and you had purchased the vehicle from me, I would have installed a new clutch and kept the old one to install on a used machine or one of my own. Or, I would have just installed the cover and you would have never known.
To each his own, but I want you to ride one of my machines and tell me which one has a broken (or multiple broken) fan blade. Here's the perfect solution - trim the broken fin, measure it and cut off the same amount of fin on the opposite side and it will be in balance again.
I have rebuilt plenty of of clutches, lots of snowmobile clutches, less atv clutches, new parts are always weighed out on a scale, adjusted if necessary. As far a balancing goes, I send that out to a local shop, they start with the inner sheave, they balance that part first, then assemble the rest, final adjustments are made on the outer cover. Any machine I have that turns over 7500 RPMs I pull the pull the clutch and have it balanced.
The Op could send his clutch in to the shop I use for balancing, but they would say no way on that clutch.
Hey Latebird, let know when I can come down there and ride one of your XP 1000 with the broken clutch.
Latebird
The OP is posting in the XP 1000 section of this forum, the picture of the clutch is of one off a XP 1000
You look like you haven't been at this too long.
I didn't pay any attention to what the forum was - I found the post under new posts and I'm used to posters describing the vehicle they own regardless of the section - guys with Rangers post on here and I can't for the life of me find the Ranger section. More irritating is those who post the same question in more than one section. These things are for recreation - not for racing or high performance and a broken fin will not affect balance sufficiently to to warrant concern. If it causes a vibration, then by all means have it replaced or re-balanced.
LOL... Yeah the RZR/RGR guys started coming on here I think because they can actually get real answers and help.
I've been expecting to see some of the Honda guys on here since they get very little useful advise or help on their home forum 😉
I've been taking care of the TRXFORUM - I know there there are others, but a guy can only do so much o_O
I'd say they're in good hands then latebird.
I was actually talking about the Honda ATV forums. In all fairness, they've got a few pretty good contributors. I haven't been on there in a while but any time I've needed a little Honda help there just wasn't much useful info. I just checked the TRXforums and bookmarked it. Thanks latebird.
Discussion Starter #17
It's a 2017 sportsman 1k. The belt exploded during a race and the cord wrapped around the 2way bearing, breaking the plastic washers. I took the clutch in to the shop so they could replace the washers. Based on the fact there are holes drilled in to certain areas of the sheaves, I figured balance was very important, especially when it's spinning at 7500+ rpm. I ride very hard most of the time so I wanted to make sure my initial thoughts were right. As far as the suggestion to take off the same amount of the fin opposite, there are an odd number of fins so there isn't an exact opposite fin. As much as I don't want to spend the money, looks like I'll be buying the stm. At least then I can replace parts if they break in the future. Cost of playing hard I guess....at least that's what I told the wife. Tha is fir the input.
You are making the right decision on replacing that clutch, I didn't want to get in to it with the rest of the experts here that its a 9 blade clutch and there is no opposite fin to grind on.
I would suggest you get your own clutch tools so you can service your clutch without taking to people that obviously don't have the right tools for this type of clutch.
Here a picture of the holding fixture I use for the ATV clutch, it works on the straight fin clutches and the curved ones.
137154
Discussion Starter #20
What ya want for the old clutch OP?
Ima hang on to it. I like to turn expensive snafus into furniture. This will be added to the collection. I figure maybe a lamp or something. Then I can put it in my man cave along with my ford tailgate neon clock.
1 - 20 of 26 Posts
