I had a slight rollover on my 2018 sportsman xp 1000 and am wondering if anyone has replaced the throttle paddle before? I ordered a new paddle off of Polaris's part website but I can't seem to figure out how to remove the throttle paddle off the fly by wire system since it has a cap on the bottom. Do I drill it out and use a screw extractor to get it off?
Funny thing I took mine off so I was going to put on a Billet but change my mind. OK all you do is pop the cap off then you need a 15 Torx (Tamper-Resistant Plus) as I used a Standard 15 T-R Torx but it was very hard and had to break that center pin out to get it to work.
Hey did you get it fixed?
drive by wire need to drill a small hole in centre of little plastic cap. screw in a sheet metal screw of some sort and pull cap off
Its a special screw call a a tamper proof IPR Torx 15. A reg tamper T15 torx did not fit. I had to order mine from the USA.
No one around in Toronto has ever heard of this screw before
check position of throttle lever for full travel because its a spline and cn go in different positions
Custom moto Quad in Canada sells alumin throttle lever and has step by step procedures to install on website
Yes, I did. thank you for the help!
