I'm going to cover one of the most overlooked carburetor problems somewhat unique to Polaris.
The BST34 carb is not a simple carburetor as most mechanics would have you believe. I am not a carburetor engineer or even a top notch tuner, but I believe I am a highly qualified mechanic and very good with carburetor repair.
Many Polaris models use the Mikuni BST34 carb and many owners experience carb problems. The BST34 suffers from a malady not seen in other carb designs. Here is the breakdown of the BST34 carb used on the 95 Magnum 425 (the same carb was used on many other models with slight changes to the jetting and other 'metering' parts.
The subject of this post is the jet block (key 10 in the breakdown).
The jet block is plastic and secured to the carb body by tamper proof Torx screws. The problem is the jet block is a replaceable part and has special D-rings sealing it to the carb body. The D-rings are not sold as replacement parts - they come with the jet block @ $70.
First, let's understand the jet block and it's function.
In this pic, you see a jet block removed from the carburetor (the carb this came out of was severely damaged by alcohol and will not be reassembled, but will work well for demonstration).
The jet block is where the slide needle jet is housed and the needle jet is held in place by the main jet. (note the white residue on the needle jet - that is aluminum oxide deposited by water that has combined with ethanol and corroded the base metal of carburetor - aluminum may not rust, but it will oxidize and technically does rust - oxidize steel and it turns brown, oxidize copper and it turns green)
The needle jet has more than one function. Notice in this and the above pics, the hole in the jet block between the two o-rings - that is an air passage. The o-rings seal the jet block from fuel in the float bowl. Air drawn through the venturi creates a vacuum drop that draws fuel from the float bowl through the main jet. The vacuum also draws air through a passage in the carb to the hole in the jet block where the air is drawn through the small holes in the needle jet to agitate the fuel and aid in the vaporization of the gasoline within the needle jet before the fuel escapes past the slide needle partially blocking the needle jet and enters the air being drawn into the combustion chamber.
Now while the D-rings are not available as a replacement part I have had success in replacing the D-ring with 9.1x1.6 mm o-rings. I use Viton rather than Buna o-rings. They must be lubed with an o-ring lubricant and the hole in the carb body the jet block is seated into should be polished with a brass brush (similar to a small bore shotgun barrel cleaning brush).
This pic is a cleaned jet block ready for installation into a good carb body: new o-rings installed, cleaned needle jet, cleaned jet and jet seat washer. Pics further down are the individual parts after cleaning.
This is not a good pic, but one of the problems with the jet block is if it cracks or splits - the plastic jet block has mold seam marks that can be mistaken for a crack - the needle jet has an offset cut on the bottom that must align with the cast offset inside the jet block - for various reasons, the jet block can split on the seal which is parallel to the mold seam.
In this pic, you can see the mold seam at the 12 and 6 o'clock positions.
Here is the cleaned needle jet - it did not exhibit wear from the slide needle - if the needle jet or slide needle have any visible wear, they should be replaced as a set. What appears as bluing in the pic is caused by a shadow.
I am not a proponent of reusing jets, but I cleaned this one for just practice
Another view of the main jet and the cleaned seat washer.
I hope you find this helpful when it comes to rebuilding your BST34 carb - just remember, carbs are not simple, they are precise fuel metering devices and all the parts have to be clean to work properly.
Any questions?
Any questions?
