1 - 17 of 17 Posts
Hey folks, does anyone know how to put
A switch in that will keep the front end
From switching into 4 wheel. On the 800
It will lock in at anytime, I want to stay in
2 wheel so I can play instead of hooking
Up and going thru. Any ideas will be welcome
You've got something wrong if it engages AWD without it being turned on. Probably has a roller cage cracked in the front differential and/or H springs or armature plate bad. The switch to lock out AWD is already on the right handlebar of your machine.
The switch on mine is likes this, left = wad
Right = 2 x 4. There is no position for 2 wheel drive by itself
No I don't have a owners manual, it's not
Engaged all the time, if the back tired slip
For about 30 seconds then the front engages,
It's done that for the three years that I
Owned it, two other 800's that I ride with
Do the same thing
Change the front diff oil 3 times.
Your front diff should not be engaging if its in 2x4.
something could be wrong inside your switch. to test it unplug your switch and see if it stays in 2wd
Discussion Starter · #10 ·
Will unplug switch tomorrow . I downloaded
The manual and read it, mine will engage
The front above 3100 rpm's. The book says
It won't . Need to figure that one out too
sounds like something in your switch or a short in awd wires, most likely your switch
You've got problems in the front differential. When you spin at high RPM in 2x4 its slinging it into engagement. Search the forum and you'll find others who've had the same problem.
Discussion Starter · #13 ·
Thanks, quess I will tear into it and check
It all out, if the cage is cracked do you like
The metal or plastic one
I put John Deere parts back in mine and have had no issues but I don't run big tires, no deep mud bogs, no big jumps in AWD and I'm careful not to let it slam into engagement. The aluminum would be tougher, and more expensive, if you are into those sorts of things.
I'd really suggest you do some extensive reading/researching on the issue first before you tear into it. Yours is a fairly common problem but I don't really remember what the guys determined to be the actual cause.
Discussion Starter · #15 ·
Okay, disconnected the switch and still
Done same thing. Changed fluid and for
Now it seems to be working. Let's see how
Long it last
If your front diff is engaging in 2wd your front diff oil is usually super dirty.
Change it, put a couple miles on it, then change it again. Its always a good idea to change the front diff oil with every engine oil change (or more often if water riding), because it holds so little. And once it gets dirty, you get funky 4x4 issues.
ive had this happen it engaged while the rears were spinning so fast it broke my hub.......all it was was a bad connection at the plug to awd
i stripped some bare wire and stuck it in the hole in the plug to make the connection tight and its never happened again
1 - 17 of 17 Posts
