1 - 2 of 2 Posts
I can not find where the battery is located in the Polaris Sportsman 2 700. It started just fine and the temp dropped now the battery is dead. I looked under the seat and it isn't there.
After you remove the seat pull the right side panel. You will be able to see the battery. You can also see it by looking behind the front tires. It is more accessible from the right side with the panel removed. First check and see if you accidentally hit the kill switch.
1 - 2 of 2 Posts
