I have a 95 polaris trail blazer 250. I'm concerned the oil pump doesn't function 100%. Can I add a small ratios of pre mix to the gas for a little security? Anyone done this.? If so what ratio do you suggest. Thank you in advance
It's either one or the other, I wouldn't do both. If your concerned about the pump, just empty the reservoir and premix all your gas. Not sure what the quad is jetted for? 32:1 would be a safe bet, but maybe too rich. Maybe someone else who has done it will chime in
I agree do not do not do both or you may find yourself fouling plugs quickly. I cannot remember the ratio but if you do a search of the forum you will find it. I have seen it on here before.
TBS
