have a 95 polaris trail blazer 250. I'm concerned the oil pump doesn't function 100%. Can I add a small ratios of pre mix to the gas for a little security? Anyone done this.? I want to keep the pump on. Not get a block off plate If so what ratio do you suggest. Thank you in advance
