Have an 05 Sportsman 500 H.O and the display flashes "hot" upon shutting it off, i had to install a master switch to keep the display from killing the battery. The radiator is not clogged at all, I cleaned the fins and flushed it, the fan works, and this flashing will start after running the machine for less than 30 seconds.
I try to enter the diagnostic mode but I am not having any luck.
A couple more issues... the display shows the wrong gear and it always displays that i am in 4wheel drive.
Any Ideas??
Wow. That's a good one.. pull your body control relay and see what it does.. cause it sounds like your getting a ground signal somewhere.. almost like the ecm has water in it
12 850EPS Short bus edition
