Jacked up the front end of my '02 Sportsman 500 to put new brake pads and the axle slipped out of the wheel, I lowered it but the axle seems too short to even reach the wheel now, how do I get the axle back in now?
I sometimes had the same issue but with the rear end. I just put a block under the lower a-arm and slowly lowered the bike.
Mark
you had to remove the axle nut to replace the pads??
Good point. I only had the issue when changing bearings or cv boots which required taking the axle nut off. Didn't have to do that when servicing the brakes.
Mark
Mark
Not even to do replace the rotors either. The shaft must be slid all the way into the inner CV, do what mvn suggested with the block under the a-arm, get the splines through the hub enough that you can get the axle nut started and manually tighten the nut until snug then torque it.
