I can't get my 2012 Sportsman 400 HO in Maintenance mode to clear the wrench. I also have problems cycling thru the menus with the button when normally using the quad. It seems it responds every third or forth press before it moves to the next section.
My 2013 400 goes in perfectly. Vehicle in N, Brake locked, hold override button, turn key to on. On the '12, it's as you are not pressing it and the odometer displays normally.'
My first guess would be a faulty switch, but I've tried it a million times (waiting 10+ seconds each time) and never got it to go once. It does at least work when the vehicle is on, just takes a few times.
