1 - 8 of 8 Posts
I am rebuilding the carb in my 2004 Polaris sportsman 500 H.O. And the long needle with the clip on the end fell out. I have a new one but I am not sure what notch to put the clip on. Any help would be appreciated.
Ok thanks another question the old one is a different shape at the top is this meant to be like this or is it just worn out
I don't know if the new one will work or not - the mechanic will have to determine that - unless the kit included a new needle jet, I would just reuse the old needle - in the pic, I don't see any wear on it.
Also, I don't know what kind of carb you have or what kind of kit you got.
Ok I’ll just put the old one back in thanks for the help
The size and shape at the point is what makes the difference in performance. If you can see it there will be a number stamped into the needle below the grooves for the e-clip. If they are the same, the use the new one. Otherwise use the original.
1 - 8 of 8 Posts
