Howdy- I'm new to the forum and need some help.
My machine-
1996 Xplorer300.
Carb: Mikuni VM30SS.
Due to the VM30SS being no longer available please help me find a replacement Mikuni carb that will work. The previous owner damaged the original carb.
I hope someone out there has done this and will direct me to a replacement!!!!
You can try to look for a used replacement on Ebay or powersportsnation.com. Otherwise there are some cheap knock off options but it seems they are a crap shoot as to if it will work right without a lot more work.
Sudco may have a VM 28 or 32 - if you go smaller it will have better throttle response but lose a little top end - if you go bigger, it may be hard to start and may not idle well, but you will improve top end
