Help/insight needed.
I have a 1999 250 trailboss 2stoke removed cleaned carb added a new needle n seat reinstalled will crank on 1st -2nd pull of rope start idle ok have adjusted idle screw air screw is closed it appears that it loading up when give it fuel from throttle about mid range just bogs out has no power at all. are floats bad or is it the float arm. at a lost here all help and in-put is thanked
