1 - 11 of 11 Posts
Hi, I just replaced piston on Xplorer 300. Now I get confused the hose from carburator, don't know where it go.Thanks for all your input
Can't really see where that hose is coming from. However, you should have one from the fuel tank, then a small one from the bottom of the float bowl for the overflow and another for the vent up toward the top, maybe off to the side. The vent just needs to go up above the upper frame rail and the overflow needs to go down below the lower frame rail so it drips on the ground if at all
The one off the carb that we can see is probably a vent. Where does the other one come from?
Discussion Starter #10
Took the carb off, found one hose go in the bottom of carb..Another is vent hose.I put the pic here like infomation may someone need it later. Thanks for all your input.Stave7119 you da man.I'm appreciated.Now time to deal with cleaning the carb. It run with starting fluid and die, no idle.
136349
1 - 11 of 11 Posts
