Hey All
I have the above noted machine. Last night after using it to plow the driveway I parked it in the garage. This morning I could smell fuel throughout the garage and saw a puddle of gas under the machine. A close look revealed gas dripping out of the bottom of the carb. There is a small line attached to the the bowl at the bottom of the carb that leads into a small plastic device that kind of resembles a tiny filter. I researched plenty of articles and forums and nearest I can tell is the needle may be stuck. Most recommend a carb kit. So, I decided to removed the carb and attempt to figure it out. There is very little information about how to remove a carb from a 2003 sportsman so I used the old trial and error method, now I think im in bigger trouble. Having removed tons of snowmobile throttle cables I was perplexed on how to remove the throttle cable on this machine. I searched the internet with very little information. So I attempted to remove the whole throttle housing from the carb before i realised i could just pop the cable off and back it out. Anyway, in my attempt to remove the housing I popped the spring off the cam. Now its unwound and i dont see anyway to take that housing off to attached the spring back on the cam. It seems trying to resolve one problem, I have created a myriad of more problems. I thought an ATV carb would be as easy as a snowmobile carb, seems I was wrong. Is there a way to get that spring rewound or a way to remove the housing to fix it? If not, looks like ill need a new carb
Welcome to the board!:med:
Thanks Bruce! I typically learn most of what I'm doing from forums....mostly sleds though. This is my first venture into ATV but up until now I didnt need to do much to the ATV.
Welcome to the forums!
If you have the throttle cable out of the way, you can use some skinny wire, form it into a loop and pull the spring back around and reinstall with some needlenose pliars .
Just takes patience ,my friend.
