1 - 2 of 2 Posts
2011 Crown Vic here with 305k miles, and today my engine light comes on. Scan at the local Advanced comes up with 4 codes on the cat converter. Guy says I need to get something called Cataclean and run it through the gas tank to correct the problem.
Is it worth doing this...will it make the engine run better or get better gas mileage?
Should I use Cataclean or some other product to get this done?
Discussion Starter #2
All 4 codes were the same... P 0430. Any ideas?
I'm game for the lacquer thinner option I've been hearing about. I see low voc lacquer thinner for sale. Wonder if it matters which version you use?
1 - 2 of 2 Posts
