CDI/ Coil issue 04 sportsman 6x6
1152 Views 2 Replies 2 Participants Last post by  Bruce!
Hi, new member here, could really use some help.
No spark or intermittent spark. The white/blue wire from the CID box to the coil is grounded. The brown wire of course is ground but the white/ blue wire should have voltage when cranking correct? With this wire showing to be grounded, do you think the CDI is bad? Polaris wants $320 for oem part so just trying to make sure my diagnosis is correct. Thanks very much.
I should also mention that the red wire going into the CDI is the only one that has power. So power coming in to CDI but no power coming out.
Welcome to the board!:med:
